Mike99
Hi All,
What a wealth of information and talent on this site! I've been lurking for over two years, and finally pulled the trigger and purchased a 98 GTX limited. We got it in the water over the weekend, and it is screaming fast. I will have to change out the gray tempo hoses, but it is running alcohol free fuel, so I haven't found any goo problems yet.
I have a question about the water regulator valve. It sits next to the white storage bucket on the GTX, and at some time in the past, it damaged the bucket. I've attached pictures. It looks like a heat related deal, maybe an exhaust leak. I don't think it is still is leaking. There was some oil film on the exhaust hose from the muffler to the hull that I wiped off after our ride this weekend. I'll have to wait until our next ride to see if it returns. It may just be some "seadoo lube" over spray...
The water regulator is not screwed down tight in the muffler, but I'm not sure I can get another 360 degree turn to get the hoses to match up again, but it is loose. There is some uncured green goo in the joint between the valve and the muffler. See the attached picture with the mirror view.
I inspected the bellow in the valve, and it looks good, along with the sealing clamp. Maybe this was replaced by the previous owner after the damage was done.
Has anyone else seen an issue like this?
Thanks,
Mike
Thanks,
Mike
