shep
Hello guys!
Dr Honda, might be your area, but if anyone else knows....
Last spring I was changing the gear and stator oil before storage. When I went to change the stator oil, I was going to do it simply be removing the fill and drain plugs, sucking out the old and replacing with new. Upon getting a fluid pump and starting to remove what was inside, it was only water…no oil…
I removed the stator housing, replaced the seal in the stator, put everything back together and filled it back up with premium gear lube.
Before heading out this year, I thought I should ask, is this something that I should be concerned about? I have no idea why there was no gear oil in the stator. It looked like someone serviced it previously and used contact cement around the seal. I had to pry away at it to get the old one off.
Just thought I should ask before it comes out this year.
Thanks guys
Thanks guys
