Water in oil
BCSRXT260
Premium Member
Premium Member
Hello,
2012 seadoo RXT 260.
Oil is like chocolate milk. Did a compression check and all 3 cylinders measured ~95. Where is the water coming from. Vessel has never been submerged and plugs looked fine. I need help. Someone mentioned backflish but I don’t know what that means.
Backflushing is the process of cleaning your open water cooling system for the exhaust components. It should be done regularly especially in salt or brackish water. If done improperly you can water flood your engine . Consult your Operators manual. RXT 260 intercoolers are prone to leaking and that will cause milky oil.
