I sure hope you folks can help with a problem on my 2003 GTX 4-tec SC
Twice now my ski has not started due to water in the cylinders. Here are the circumstances.
Ski was running rough on a short trip.
Pulled the plugs and found number 1 slightly water fowled.
Replaced plugs and it ran great on the trailer.
Did a compression check and all 3 were within 2 lbs. of 140.
Replaced jet pump, drive shaft with new seals and bellows, rebuild SC (overdue repairs).
Ski ran great for two days of intense usage.
Shut it down for an hour and it would then only crank without starting.
Towed it to the ramp and took it home.
Pulled plugs and found slight water fowling in all 3 cylinders and milky oil.
Dried cylinders and plugs, engine started right up and sounded great.
Changed oil three times.
Put ski back in water to test and run vigorously to dry remaining moisture.
Brought home to flush and it wouldn’t start.
Pulled plugs and found water fowling and milky oil again. Number two cylinder had standing water in it.
During the entire time, there was never any water in the bilge.
The water in the cylinders is clear (not antifreeze) and I’m not loosing any coolant.
I’m at a loss right now. The first time it died, I thought we got some water ingestion that I didn’t know about (Riva intake system). The second time was only me and a very dry run. My next thought was the first time was water in the fuel, then the towing forced water in, but that doesn’t explain the second failure.
Through all the flushing, running and oil changes, the cooling (flush) hose was always off whenever the ski was off (ski on then water on, water off then ski off).
Thank you in advance for any help you can provide.
