Hi everyone, Through a series of stupidities, I half submerged my brother in laws XP with one spark plug removed.
The pump worked well, and I used a shop vac, and had the compartment mostly empty of water in just a few minutes.
I searched what to do with water in the cylinders, and read to crank the engine with the plug out. So I did that, and sprayed water out, and dried it as best I could with a rag.
I put new plugs in and tried to start it. No go. (Thats is the part that I'm worried might have done some damage).
I pulled the spark plug and tried shop vaccing water out. The water came out infinitely- like, way more water than could be in the engone or even compartment.
So it seems water is coming from the lake directly into the engine?
The oil is clean. The gas tank level doesnt seem changed (but maybe the reserve tank? I can't see that)
I took the air filter cover off, and the filter screen. Water is coming up and out that, especially when I lean forward. That's a couple feet up from the compartment floor, and the water only sits a half inch deep there. How is the water coming up so high?
Any advice? Would this be easier to diagnose in the water (at dock) or on the trailer? I feel like I can see more where the water is coming from in the water, but my concern is that at some point something goes wrong and it sinks!
