It seems like a lot of water builds up. I cleaned the carbs today and replaced all the gas lines. It ran AWESOME! But after 30 min or so, it started to act up. The water was up to the lower part of the flywheel, so when I start it with the seat off, you'd get sprayed from the rotation of the flywheel in the water. I am guessing the carbon ring will be the next part to replace. I am hoping beacuse of the excess water, it drenched everything and perhaps that is why it stopped running awesome??? It has a K&N filter, and it seems like water seeps through the filter into the carbs. The carbs had water dops in them. I am no means an expert, but does this sound possible? Maybe I'll put the stock filter assy on. It looks like it would be a lot better for keeping the carbs dry.
How does the bilge pump work on these things? I assume it's the RPMs that suck the water out? Doesn't seem to be working.
