Water in all cylinders after launch
Mojosolid
Ok I’ve got a seadoo RXP 255
Last week almost sank because a bailer line came off . Brought it home pulled plugs cranked u till no more water came out . Changed oil cranked again, no water came out . Went to ramp this am , backed her in enough to start on trailer . Locked up immediately . Brought back home pulled plugs , much more water than first time😱
I need some help!! Thanks for any and all input
your in the wrong section of the form. but to answer your question, you have water sitting in the intake tube that goes to the super charger. pull the intake off the front of the supercharger and drain all the water out of there and get all the water out of the engine and reconnect and you should be good.
when you try to start it the engine and supercharger are sucking what's left in there into the cylinders. Ive had this happen to me once
