Thetolleyman
Customer brought me a 2001 Sportser LE, single engine 947 Carb'd
It won't rev much over 4300 rpm according to OE tachometer.
Seems like its missing a bit all rpms.
I put in new plug properly gapped and go for a run, this is what I get after 10 minutes. One plug wet and black, other one, what I think is called "water fouled". Its got a milky tan fluid on it like water mixed with oil. Below is a pic of the water fouled plug as soon as I pulled it out, and another after I wiped it off just to give you an idea of what was on there.
I repeated this test, just to confirm, and got the same results. I removed the carbs, went thru, reinstalled, ran test again, same thing. Any ideas?
