millerjustin82
Good afternoon everyone.
So I took my boat to the lake the other day, after some overheating (mild overheating) issues to see how it's running.
Was pleased to see that the boat is running at at civilized 73-76 degrees. So we kept it in the water most of the day using it periodically to pull around the odd wakeboarder and such.
When I pulled it out of the water at the end of the day and pulled the plugs there was an alarming amount of water inside the boat. It drained for about a minute or so. The water was also very warm.
When I got it home I hooked up the hose to it and ran it for about two minutes looking to see if any water was coming in from the exhaust end of things and did not see any drips, drops, or water of any kind.
So two questions: Where should I start looking? My next action is going to be to bring it back to the lake and have someone drive around while I've got my head stuff inside the boat to look for the leak. I'm thinking maybe a shaft seal? The boat only has 40 hours on it and has not been abused.
Second question: Aren't these boats supposed to have an auto bilge? If so mine has not worked since new, it's never come on by itself.
Also, while checking the hull integrity (filled boat with water) to see if it was leaking from somewhere, I found a small gob of black silicone that looks like it was originally put in place to plug something, although the origin of this "plug" still remains a mystery.
Any and all advice would be greatly appreciated.
