JPass
So after reading the owner's manual I got the idea that instead of buying a hose pincher should I ever need a tow or if I lose one of the engines and need to get back, that I would rather add an in-line valve to the exhaust water supply hose where the manual states to pinch the hose.
I'm aware that if left closed it can damage things (same if the hose pinchers were accidentally left on), but aside from that I don't see any reason not to add them. I found brass ones at HD for $10 each. I could always leave them open and remove the handles (keep them in the glove or flare kit) and simply put the handle on should I ever need to close the valve.
Anyone else do this?
