Wake tower
I would say post a photo of the boat and what you have. If it's the X20 tower base, the rest could possibly be ordered, or the OEM identified. Otherwise, you are just guessing.
There may be a tower that would attach by clamping to the base you have as well. But if it's a SeaDoo tower, only that tower will fit the original mounting points. Of course, that tower was manufactured by some OEM other than SeaDoo I would guess.
biffdotorg
the WAKE TOWER looks the same as in you pic above. Will see if i can find that part number and see if anyone carries or even sells it anymore.
thanks!
biffdotorg
thanks!
Well, here is where you start. The Parts list on SeaDoo's website. Choose the 2002 SeaDoo X20 and pick the Body and Accessories Page 5. All the tower parts are listed there.
http://parts.sea-doo.com/Index.aspx...58ahmhu14&catalog_id=0&language_id=1&siteid=1
That would be where I would start. Even if you searched for the parts you already have, it may lead you to a vendor that can order the rest. Your seadoo dealer may as well. Print out the parts list and check.
Good luck!
