Wake Tower Install Question???
jster91
I have a 2004 Utopia 205. I purchased a MT1 monster tower. Will I need to reinforce the hull at the attachment points near the front edge of windshield or near the side behind the driver's seat? Anyone done this before?
Thanks
Jeff
I believe you will need to add a piece of marine grade plywood on the inside of the hull where each leg of the tower attaches to keep the stress on the fiberglass to a minimum. You can get to the front easily by removing the seat backs in the bow section, but I'm not sure on the rear. Might be a good reason to add another set of speakers and use those to fill any access holes you need to make.
Aaron:cheers:
When you drill your holes for the bolts measure the thickness of the fiberglass. If its less than 3/8" you must reinforce. As for access holes. Cup holders are another idea. But I would try to keep the holes in hidden places to make it easy on yourself and ask someone that's skinny with long arms to lend a hand.
