Hi guys could do with a massive help.
I currently have a wake pro 230 2018 model. Owned this ski about 1 year.
Recently I have been having an issue that the ski will throw up a fault code P0298.
The code appears around 1 hour or more of riding and the ski will say check engine and the light will come on and the ski will go in to limp mode. But then when you let go of the throttle about 5 to 10 seconds the engine light goes off and the ski resets itself. And then the ski is back to normal for a few minutes.
Most recently I had noticed that when going at full throttle in touring or sport mode this is the majority of the time it will happen.
Prior to this happening I did notice that my ski will beep sometimes hitting some hard waves when Landing.
Any ideas as this is rattling my brain and the dealer is no help.
Oil pressure switch night temp sensor changed new wear ring as well and it is still happening
Thank you
Thank you
