samdoo
230 Wake 2008 help needed!
Hi guys. New here.
I have 3 questions if any one can kindly help with each:
1- I need help to find the fuse map for the Seadoo 230 Wake 2008.
I was using sound system and it went off. Lighter on the panel that was connected to GPS is off too but electrics else where are fine and engine turns on as it should. I guess it is a burned fuse but only if could find where it is located and which one.
Also music was on loud side but not too loud. Now why the fuse should go off? Do I need a second battery or have to listen with low volume all the time?
2- One of the engines is running about 200 rpm less than the other now. It wasn't like this before but other than that engine sounds solid and no drop in speed. Is this normal or I need a service?
3- Fuel gauge has never worked right from beginning. Is this a common problem and what can I do to see it work?
Thanks for help.
Hi guys. New here.
Thanks for help.
