despower
Hey guys,
Thanks for all the help in the past.
Am having a problem with Sportster. On startup, I get a 2 second beep every 58 seconds indicating a code 5. I checked the usual suspects for code 5, one of which is a battery problem. I removed battery and made sure it was fully charged with an external charger. Reinstalling the recharged battery eliminated the Code 5 temporarily. After 5 minutes or so at 3500 RPM, I tried to rev up past 5000 rpm to make sure it was out of limp mode. When it got to 5000 rpm, the code 5 beeping started again. I dropped the rpms back to 3500 and checked the battery voltage - it was at 12.3V. With the Sporter stopped and battery switched off, the voltage reads 12.65V. This sounds wrong - I thought the regulator should bring the voltage up to ~14.4 Volts when running in order to enable the battery to charge properly.
So, does this indicate a faulty regulator or faulty battery? Note that I have not thoroughly checked the other code 5 problems yet - it seems to me that the battery/regulator might be the culprit.
