henryb
I have seen this for quite some time, where, when I start up and after it warms up a bit... The dash mount volt gauge reads quite high, 15-16 volts.
Last year when I was getting the Stator swapped out at the local shop, I had already purchased a replacement voltage regulator and they swapped that part at the same time (this issue was happening before the stator change).
Normally, I just click on the blower and it will cause the voltage to drop back a couple volts.
If I don't turn on the blower, it seems that the voltage regulator does do its job eventually... Once the engine revs up a bit, the voltage will also creep up and once it gets over 16v, the regulator must cut in and it drops down to 13-14v range on its own. It's seems to stay there for the rest of the ride.
Not sure where to go from here? I compared the dash mount volt gauge with readings from a good volt meter directly on the battery, they are very close, within .1 volts. So, I don't think it's a false reading?
Any suggestions?
Any suggestions?
