Video of speedster 150 w/thru the hull exhaust/lots of mods
VIDEO: View attachment SPEEDSTER PICTURES OF AIR INTAKE-FAB THRU THE HULL EXHAUST fnl.pdfSPEEDSTER PICTURES OF AIR INTAKE-FAB THRU THE HULL EXHAUST fnl_Page_09.jpghttp://www.**************/forums/showthread.php?t=219718
Some have asked for a sound clip of the Speedster 150 W/thru the hull exhaust. Was a stock 215 hp engine. Mods include: X charger, Fizzle 4" air intake getting outside air, thru hull exhaust(eliminated 2nd muffler, etc.), Riva catch can, stainless wear ring, Solas Concord R impeller, R & D pump seal, etc.
Notice the steam stack on port side when you hit it, it will blow water over 10 ft. at throttle. Exits above the water line, unlike most setups, and doesn't set in the water when setting. I sunk a 2008 RXT-X when clamp came loose from the exhaust tip that was under water setting. This OEM boat setup has the exit under water if not under power. Your entire existence is based on a clamp. Stupid design, done so to be quiter, etc. but not for performance or safety. Couldn't keep it WO long due to the chop and it starts getting faster than you want to be in it in rough water, you get some serious air! The jet pump water hits a normal ski rope when WO. It will blow off 260 OEM Seadoos in this chop. Before the mods, that I bought all from Jerry and used his advice, I was running the boat WO most of the time and could do so from the hole. Now, we have more than you can handle if you just throw the throttle WO. It will literally jump out of the water doing a water wheelee in you hit it all out of the hole, so now, which I like, you have to feather the throttle so not to lose proper attitude. NO REPLACMENT FOR DEPLACMENT.
Notice the cherping sound from the X Charger. Also, this is at 5,000 ft. altitude, so much more at sea level. A stock 255 RXT-X runs about the same here as a stock 215 hp does at sea level.
  • SPEEDSTER PICTURES OF AIR INTAKE-FAB THRU THE HULL EXHAUST fnl_Page_11.jpg
  • SPEEDSTER PICTURES OF AIR INTAKE-FAB THRU THE HULL EXHAUST fnl_Page_19.jpg
  • SPEEDSTER PICTURES OF AIR INTAKE-FAB THRU THE HULL EXHAUST fnl_Page_26.jpg
  • SPEEDSTER PICTURES OF AIR INTAKE-FAB THRU THE HULL EXHAUST fnl_Page_08.jpg
  • SPEEDSTER PICTURES OF AIR INTAKE-FAB THRU THE HULL EXHAUST fnl_Page_03.jpg
utube video of speedster http://www.youtube.com/watch?v=HIxPe4K7x18
VIDEO: View attachment 26442View attachment 26443http://www.**************/forums/showthread.php?t=219718
utube video of speedster: http://www.youtube.com/watch?v=HIxPe4K7x18
