I was running my 210 Merc Speedster today pretty much wide open today. I lost power and heard a constant clicking noise. (not a bearing type noise -sounds like its in the pump) The engine sounds fine otherwise. I idled it about 3 miles home and didn't shut down due to worries about getting back to dock before dark. I've looked at the impeller and it looks normal as far as I can tell. I didn't think to try a restart -just put it on the trailer and stuck it in the garage. I wish I'd tried it again -didn't even think I might have a stick in the intake (duh). Its gone now if so. Also, noticed the hull took on an abnormal amount of water it seemed when I pulled the plugs. Anybody have a suggestion on what to check if it sounds the same in the a.m. in the driveway? The sound was like something hitting a fan (constant). I've read alot of your posts concerning wear-rings. Is that a possibility? I'd sure appreciate someone pointing me in the right direction (except to a shop). Thanks, Frank
