Utopia185 Blower
Utopia185777
I am having difficulty determining problem with blower motor. The blower does not work. Did a direct hook up to battery and the blower works. Did a continuity check on the wires and switch and everything appears fine. Anybody have any ideas with what the problem is?
fuse? If the engine blower works with direct hookup but not on the original wiring then you either have bad wiring, a bad connection, a bad fuse/tripped breaker, or a bad switch.
