I sucked up a ski rope yesterday into both drives. I had this happen to me on my last boat and cleaned everything out and it was all good. This is on a brand new Utopia with about 15 hours on it. It has twin 155's. Non-supercharged obviously. I killed the engines and cut everything out. I inspected the housings, from underneath and from the rear of the boat, and it is clear. Today I took the boat out and it started to have really bad vibrations after 4000 rpm and and lack of power on the starboard engine. I gave it a little gas and it literally transitioned back to normal. It was running fine and then I restarted it after having lunch and it started the same thing again. It seems fine except with a little more vibration under 4000 rpms. Over 4000 rpms is when the really loud vibration starts and lack of power. Sometimes it would run rough and then transition back into smooth operation.
Also, yesterday (it was a bad day), hours before I sucked up the rope, one engine was not performing smoothly so I removed the third cylinder spark park plug wire boot from inside the engine case, pulled it out and pushed it back on (because it did not look snug) and the boat ran fine again. Also, the steering seems to be pushing the boat starboard (which makes sense for a starboard engine lack of power) Any ideas? Do you think its a damaged impeller ring or should I have the dealer look at the third cylinder? Could it be flooded or damaged if there was no spark but still running okay under 4000?
