I just bought an '07 Utopia. Have used it two days. At first, noticed some issues with the DESS key-wouldn't always start when put on the post, would remove, re-install, and then would start. Today, after returning from the beach to a dock, I attempted to restart the boat, and it would not start. Got a pair of two beep signals, I could see the gage needles peg and return to normal, then got a procession of four beeps, pause, four beeps, etc. Everytime I pressed either of the start buttons, nothing would happen. No cranking, no clicking...nothing. I checked the owner's manual, and was given two options for this signal.  The "four short beeps every three seconds" means that the DESS key has been left on it's post without starting engine, or after engine has been shut off. Or the other choice in the manual was If the four beeps are heard while pressing the start/stop button, then that means the boat isn't in neutral.
It would be correct that the DESS key is installed without starting the engine, as that is what I was trying to do with no luck. So, option 1 from the troubleshooting page really doesn't apply. Well, actually, it could apply, as the DESS key was installed but despite repeated attempts at pressing the start button, nothing happened.
The four beeps were not heard only when I attempted to start either engine. The four beeps with a pause, then repeat, occured whether I tried to start an engine or not.
So, a few questions.
1. I get two pairs of beeps when I insert the DESS key, ie beep/beep, then beep/beep. The O&M says that two short beeps means it is OK to start the engine. With a two engine boat...does that mean I should get two pairs of beeps (four beeps total) and not just two? Since this boat is new to me for just a couple days, I honestly don't remember the number/sequence of beeps that I heard the few times that it actually started up correctly.
2. If the two pairs of beep that I get means that the engines are ready to start...why don't they start when I press the button? I thought that the four beeps may mean I wasn't in neutral, so I repeatedly moved the forward/reversee lever to make sure I was, in fact, in neutral...but that didn't help the matter.
Any suggestions on what the problem could be?
