Greetings,
I have an issue with my 2004 Utopia 205 Optimax 250. I had the engine rebuilt last year so I took it to a shop that had the Mercury software to check it out. The engine checked out fine and was reset to show 0 hours. Here's the issue. The engine starts and idles fine. I take the engine up to higher rpms and I get a beeping. The first time it happen when I backed off the throttle, the beeping stop. The tachometer wasn't working so I didn't have an indication of the RPMs when the buzzer started. I installed a smartcraft gauge that I had since the tachometer wasn't working and took it back out. This time I was able to see with that once the RPMs hit about 1750, the alarm/buzzer went off and did not stop when I pulled back the throttle. In addition to the buzzer, the smartcraft gauge showed the bell and the engine icon. I drove the boat back to the dock, shut the boat off and restarted and the alarm went off. When I look at the smartcraft operational manual, the code bell and engine icon means engine malfunction. Not sure what this means since the smartcraft operation manual doesn't have anything in it to indicate what this is. It appears it could be like a check engine light. Any idea how to troubleshoot?
Thanks in advance.
Thanks in advance.
