markkellyjr
ok i have the 97 spx 717 it wouldnt rev over 1500 rpms. one of you guys told me to change fuel lines and clean carb. i cleaned carbs changed lines and re adjusted the low and high jets. it runs alot better but still same problem.but now it dies at 4500 rpms. its getting plenty of fuel to carbs,but it looks like the one in the back isnt getting as much as the one in the front. both plugs are wet with fuel when i pull them out. if you feather the gas and keep it under 4500 rpms you can ride for an hour or more with no problems. clean or change plugs and still the same thing. i found a loose ground wire bolted on top of coil mounting bolt.fixed that still same thing. its almost like its loosing spark at high rpms,but not sure.do these machines have a high and low coil/ stator? please help im to the point of making an artificial reef out of it or a flower pot. could it be bad gas?
