Explorgm
I have kids and needed a learning key for my GTX to slow it down while they learned to operate the skis. My 2006 GTI came with one that regulates the speed to the 32-35MPH area with no adjustments. Seems to be perfect for the compromise of fun versus safety while they are learning.
At the urging of those on this site, I purchased the Candoopro and a learning key. The Candoopro programmed the key to the GTX with no problem once I got through my own learning curve. I was also able to change the ownership in the computer as well.
The problem came when we took the GTX out for its first run with the learning key. It would only go to 10mph! Took it back in to the slip, checked it out for issues and took it back out with the master/yellow key. No problems with that key. Took it right up past 35 and later when the kids were gone to 50.
The next day while the kids were not around I tried to change the setting on the ski to 32mph for the learning key. I found out that #1 was indeed set to 10mph. #2 to almost 20ish mph etc... The top number, #5 I think was the 32-35mph speed. So I set it on the highest number and that meets our needs for now. The curious thing is that I have read in the manual that the 32mph should be the #1 setting with faster speeds as you move up the numbers?
Has anyone seen this before? Is there a fix for it? The ski has 30 hours on it so not used much...
Thanks!
Thanks!
