rkkoeb
So I am looking at adding a set of underwater transom lights on my speedster 200. I will most likely install my switch on the main dash panel but looking for the best way to wire up the lights? Is there available power inside the dash that I can tap into for the switch or do I need to pull wires up from the engine compartment? I don't want to come right off the battery as I want to make sure the lights go off if the main discount switch is turn offed. Any help would be great
