Hello team,
I am kind of new in the "business" i own a challenger 1996 modified with an engine 2004 rotax 1503 4tec and a RXT dashboard (pictures on another thread). Now, i have beed a few times on the water i kind of learned how to use it but, as an engineer and because i LOVE it and how it drives i would like to find out a bit about functionality, especially the engine in order to take good care of it. And here goes my first set of questions:
1. The RTX dashboard .. does it have a back-light ? mine does not ... is there a wire I am missing (one of the picn should power the backlight? or no backlight at all ?
2. How does it know the cardinal point that is being displayed on the LCD ? ... the sensor is inside the dashboard or it is an external sensor ?
3. this is the tough one .... How does a jet engine work ? ... i understand that is has a 4 stroke engine ... that connects through an ax to the propeller that is inside the channel between the bottom intake and the jet nozzle at the back of the boat. That is in big terms how i see it. But how does it cool the exhaust ? where does it take water from and how does it throw it out ?
4. I understood I have 2 cooling systems, one closed circuit for the engine itself (cooling the piston housing) and the second one with water lake cooling the exhaust .. right ? How often do i need to replace the cooling liquid ? How to take the old one out ?
5. For the engine oil I saw a video on youtube about how to remove the old oil (with a suction pump) through the "oil level indicator". How much oil this engine has ? What kind of oil should I replace it with ? How often to do this ?
6. Is there any other type of oil or lubrication I should do on a regular basis ? like bearings etc ?
7. I have 3 levers on starboard side. 1st is forward-n-reverse, the second on is the acceleration and the third one i have been explained it is the VTS (variable trimming system). I realized that this one lifts or lowers the water jet. Now when the boat is not running i can put it in either position. When in speed (30 mph) i can only have it in the forward position and then the bow is a little bit raised or at the middle and then i get full speed but i get a VERY hard resistance (and i am afraid to pull more not to brake something) to set it in the "back" position .. why is that ? What is the "back" position for ?
8. I have opened the dashboard and on the RPM meter on the back there is a sort of small tube (it reminds me of old vacuum controller gauges). Nothing is connected there ... what is that one used for ?
9. I have successfully installed a hummingbird 153 fish finder and it works great. I have installed the transducer on the stern, and run the cable through the "old" water in hose. (while modifying the engine a new "tap water in" has been added and the old one was filled with silicone. 99% of the time it words great but sometimes, when driving in forward, not high speed i get for 2-3 seconds random reading of 80 - 100 m depth while in 3-04 meter water. Does anyone know what could be a reason ? Is this something that usually happens ?
10. Under the jet part (i am going to name it "jet exit" the part that throws the water - maybe someone tells me exactly the name) the guy who modified the boat added 2 plates of metal. The guy i bought the boat from is not the one doing the whole modification but he explained me that the "jet exit" is kind of long and in order for it not to be slammed by waves while a jump the metal place part has been added. Now i see that that metal part looks like a chamber (double wall) and in fact there are 2 hoses going inside it at each end (left and right). Was this indented to be some kind of radiator for the coolant liquid ?
11. yesterday I was at a boat ramp where there was a lot of grass. I guess it sucked grass into the intake because when i tried to accelerate there was a strong vibration and no power. Then i put it in reverse and accelerate a few times until it blew the grass away (i think) and then it was all back to normal. Is there another way to solve this problem ? And speaking of which what happens if i go in a shallow water and mud or sand gets sucked into the intake. Will that damage the propeller inside the turbine ?
I know i have asked a LOT of questions ... I am just curious (being an engineer) to find out as much as I can about this boat and be able to maintain it. I need to tell you that i have watched LOTS of videos on youtube and read articles but did not find the answers questions posted above.
Thank you !
Thank you !
