Unable to start after a morning of ridinf
Redneck-pontoon
I can’t start my Seadoo wake pro after turning the engine off to drop someone off at the dock. When I go to start the engine, the screen blinks on and off a few times. I pulled it out of the water and charged the battery, but it still doesn’t work. Anything else I can try to do to fix it?
Your description sounds like either your battery terminals are loose, grounds loose, or the battery is bad. Check all your connections to be clean and tight at the two battery posts, at the starter, and grounds (likely 3 bolts on the front of the engine under the oil filler tube). If all clean and tight, I think you likely need a new battery because it isn’t producing enough amperage to start the ski.
