hello guys,
I am glad to find this forum. I own a seadoo challenger twin engines and this summer I started having issues. Hope someone can help. I owned it a while however I am clue less how to work on it.
Here is the problem.
About three weeks ago I noticed when I push both throtle controls equaliy, left throtle (loose) does not add speed to RPMs till half way. After half, its sensitive. In order to use it have whatch RPMs and push the control as carefull as possible.
- Here is what I did to fix it. Took it to seadoo dealer/mechanic. After two weeks working on it, they claimed they fixed it by cleaning both carbs, and FISHING OUT BROKEN NEEDLE-HMMM out of carb.
I called as soon as I tested the boat and told them that they have not fixed a problem that I had. I will have to call tomorrow again. But I am sure they will charge couple of hundred more to fix actul problem.
Help from you.
Let me know if I can adjust anything to make this work.
Please and Thank you.
Selmir :cheers:
Help from you.
Selmir :cheers:
