Machinehead
So, unfortunately I am in the same boat so many of us find ourselves in forums like these. I have just left my 2 1997 GSI's at what was supposed to be a certified sea-doo sales and service facility for 3 months. Stroked a check for $1250.00 for both, told they were 100% and ready to go, put them in the water and they both had the exact same issues as when I dropped them off!!!! Freaking crazy.
I know they are old units but they are great machines that never get used. One has 47 hours and the other has 43.
So not to bore you with the stupid details of an incompetent shop, we have all been there, I will just jump to the issues they are having. Maybe someone can point me in the right direction.
Jet Ski 1 issues - Put in the water starts right up and runs perfect. Lightning fast and pulls up on plain and operates as it should. Shut it off for a minute and return to it, when going across the lake at full throttle the RPM drop and makes it surge. It goes up to about 5800 Rpm and the throttle goes dead (Does NOT Stall) Just no response from throttle until it drops down to 4500 RPM than kicks right back in. It lets you accelerate until hits that 5700 Rpm mark and drops right off. creating a surge effect. Crazy because initial drop in the water the thing is perfect. So I'm not sure how much is to do with RPM or engine temp. But several hundred $ later. New wear ring, new drive shaft plus other items......still does the exact same thing.
Jet Ski 2 issues - It is flashing Low Fuel, Low 12 Volts, Low Oil in dash display as soon as you start it. Fuel is good, oil level is good and I was told it wasn't charging. It will start and run all day on trailer lowered into water. You can throttle it up on the trailer and it seems to respond fine. Put in in the water and throttle it up, the second it tries to come up on plain, it falls on its face and drops back to an idle. It does not stall but can not get it to power up under a load to get it to start to come up on plain. Does not sound like it is missing or any engine concern. Its like it starts to pull up and like you just release the throttle. This has new stator, fuel sender, oil sensor, some amp regulator. All stuff I was told would fix it right up. Yup FIXED NOTHING.
And help or advise would greatly be appreciated.
