Tsunami Ballast Pumps on 210 Wake
sandals99
hello all,
In my 210 Wake edition, the fill and emptying of the ballast is not working. No matter if select fill or empty on the switch, I don't hear the pumps working. So I took an RC battery pack I had kicking around and connected it to each of the pumps and the pumps started to run. This made me want to check the fuse for the pumps, but the problem I am having is that i can't find the fuse(s). I started looking from behind the instrument cluster and traced the wires as far as i could and nothing was to be seen. I went to the fuse panel for each engine and nothing there was labelled for the ballast.
Any thoughts on where the fuse can be located?
Worst case scenario is that i am going to get a 12 volt extension cable and run that from the 12 volt adapter to the pumps manually if i need to.
thanks!
after market install?
check for inline fuse some where!? should be a 15a
i am try to trace the wires to find the inline fuses. I don't think it is aftermarket because the switches on the dash look to be factory and so does all the piping for the water in and outflow. just not sure why i can't locate the fuses, really odd
