gerrychuck
Hello, all; I am a new (as in today) owner of a 2002 Challenger 2000 with the 240 efi. My son (an apprentice auto mechanic) and I did a brief checkout pre-purchase, including compression check (120's across the board)and checking plug condition and gap. The battery was dead, and we threw an industrial charger/booster on it, and started the motor very briefly (about 5-10 secs) to make sure it would. I took delivery of the boat today, and ran it out to the lake to try it out; the battery was still low (predictably) which I had kind of conveniently forgotten about, which led to attempts to charge it up with booster cables. I seemed to be quite difficult to get the charge up, and eventually we boosted it in the water (that was a bit of a process) and got it started. It idled fine, but there was a whining noise from the instrument panel; it wasn't very loud, more annoying than anything, and I couldn't tell if it was supposed to be a warning or was in fact a normal sound for that boat. Unfortunately the seller had forgotten to bring the manual so I didn't have anything to refer to. We idled away from the dock, and when I tried to advance the throttle the motor bogged until I brought it back to idle, then I tried to advance the throttle again and the motor died. Despite the time on charge and having run for 5-10 minutes, the battery was deader than before, and we ended up paddling back to the dock.
So, a couple of questions. First, I have read here that there is in fact a low voltage warning in the boat; is that likely what I was hearing after startup? Second, if the battery was still very low on voltage, could it cause the boat to die when I started to bring the power up? If not, any ideas about what the issue might be?
I am giving the battery a thorough charge tonight, but I suspect the battery is pooched, and I'm hoping that's all that's wrong. I might try starting the boat hooked up to the hose briefly tomorrow (probably will need my booster pack) to see if the warning is still on when running with a charged battery.
Last question: the flush port is on the starboard side under the engine hatch, right above the battery, yes?
Thanks in advance for any assistance here; I'm looking forward to participating on this forum as I learn about the boat.
