jaybird
Hello all,
I am new to this forum and new to the whole boating scene entirely. I just bought me a 2006 Sea Doo Sportster 4-tec. I tried to do all the research I could in order to make a good buy. Tested it out, ran it for more than 30 minutes on the water. The guy admited to the RPM gauge and speedo gauge not working. I figured I could fix that or replace the gauges. Otherwize the boats engine ran well, good compression, started quickly, and seemed to have no problem. I take it out on the water for the first time this past weekend and right from the start I get warning lights and a long beep about every 2 minutes maybe? So back to the dock I went. I noticed before the beeping started, and while it was beeping, that all 4 warning lights on the warning light gauge was blinking too, and when it did, they all blinked together at the same time.
Sorry for the length of this, I just wanted to be sure I included everything. I brought the boat back over 400 miles going about 65 or 70 mph. My first guess is did something shake loose to give this warning, or whatever this warning is, or if it's realy a warning or just electrical? I checked the oil before leaving the water, it had been off for about 10 minutes after running about 10 minutes. It may be ever so slightly over filled, but barely, if that was a good time to check the oil. Other than that, the boat seemed to run fine, no smoke or anything like that. Sorry so long again, thanks in advance! :banghead:
