Does anyone know if Trigger Coils are universal? I don't see any used ones for a 97 GTX, but there are a few newer models on ebay that I thought about trying.
The newest replacement part runs between 90-120 dollars.
If it's from a 787 engine it should work. Do yourself a favor and get one from Nick [MENTION=41828]Minnetonka4me[/MENTION], he'll treat you right and you will know it will work. Or if you want a new one order from this site. I didn't look it up but 420966832 sounds like a part number from a 4-tec ski.
I'm installing the trigger coil now and just want to confirm wiring. The black/yellow wire is on top and the solid yellow is just below that. I don't see anything in the shop manual, just wanted to confirm the existing wiring is correct.
That's how mine is wired, thanks for the confirmation. Crossing my fingers the trigger coil does the trick, I checked the crank and it seems to be fine. After the trigger coil, I'm down to Rotary Valve and MPEM as my last options to check.
