Mickirig1
Please add to this. Your tricks and traps.
Read, Read, Read, all you can on the site. The Carb tuning Sticky above has a lot on info! Read it over and over. It explains a lot on carbs. Watch videos of carb rebuilding and cleaning on the Internet.
If not done yet: Replace the gray Tempo gas lines. Clean the factory fuel filter. Clean the fuel selector valve or replace. Add an inline fuel filter. My carb the top line is return, the bottom is the in line. Use 100% stainless clamps. Make sure your gas tank vent valve works. It can cause pressure to force gas past your pop off. Gas fumes in bilge is not good on start up!
1. Note how the throttle cable was on carb,if you put it back 180 degrees from where it came off, the slack is gone. Readjust slack into it and adjust oil pump cable.
2. Take pictures as you take it apart. You will thank me!
3. Have it in a pan or container that will catch parts and little screws. As you take it apart.
4. Screws that are too tight need loosened with a hammer powered impact driver. It's not worth making a phillips screw head into a funnel shape. On a piece of wood oppsite .Turn barrel of driver in direction screw in coming out. Light / Medium hammer hit should do it.
5. Make a tool out of a 10 penny nail ect, to install the round plastic check valves. It's a 2mm ball with a smaller shank. Ground with a bench grinder, air cut off, dremil with cut off wheels.
It can be used to remove the small rubber plugs that anchor the valves. Then practice with old parts installing the old parts, lube with oil. Then, New stuff goes right in, no problem!
6. Keep old parts away from new. Take pictures!
7. Check pop off at least 3 times. WD40 sprayed to fill up depression it's in. Protect eyes.
8. Carb cleaner is no friend to plastic and rubber parts!
ADD TO THIS PLEASE.
ADD TO THIS PLEASE.
