Hello, not sure what happened, but my trailer hook on the boat is a little loose. I have a small 1" crack running below the hook, and some flaking outer coat near it. When I push in on it it is pretty firm, but a little softness. On the inside, i do not see any cracks coming through.
I can of course tighten the bolt heads, but this could force the metal backing to go right through the fiberglass and I have a bigger problem.
Is there a way I can strengthen BOTH the inside and outside hull in the hook area?
I thought I could put some type of compound in the area after taking out the hook, but if I make it too thick on both sides, the screw length on the hook will no longer be long enough with the added fiberglass.
So, what to do? Is there a strengthening compound for inside and outside of the hull, and how can this all be done?
Thanks
Lar :blush:
Thanks
Lar :blush:
