So what do you guys recommend for a bimini top? if you have pictures that would be great!
Also, I know I asked about the towers, I dont think I should put in a tower if it did not come from factory... but what are your opinions?
I bought just a standard bimini-top and made some minor adjustments at the two bars behind. (had to shorten them and changing the angle)
After the change it just fit to the original fittings. I'll post some pictures soon when I'm back in Germany.
I'm sure you can find a equal bimini in the states.
http://www.bootszubehoer-maier.de/B...--Sonnendach/Bimini-Top-200-213cm-Breite.html
Wow they look nice, thanks guys, you know I installed a Bimini for my previous sportster, this time Im going to do something different, I'm going to install it without screwing holes in the hole, just using some powerful 3m double sided tape what do you think?
That's not going to work. It will rip off within the first minute out on water. Nothing wrong with drilling holes. Just buy the oem Bimini and follow the directions. The next owner will think it came on the boat.
Ok, it just freaked me out drilling holes in the hull before
I hope that cheappc don't sell his boat for next 10 years minimum LOL
I see that you got 1998 speedster and that thing looks a beauty to me..... I wish I'd be able to keep my boat that long and that clean
Those middle mounts which are bolted on, are what holds the bimini on the boat. The straps only purpose is to pull the front and rear bows tight. The oem sea doo bimini doesnt use straps on the rear. It uses another set of mounts and rear poles. This allows you to leave the bimini up and folded back. So it is ready to go, when you want to use it, just remove the boot, pull it open and clip the front straps. Trust me, it is very nice and you HAVE to bolt it down. Its easy to install though. The oem bimini is a much better quality too. It is more rounded on the top instead of flat like most cheap ones.
Here is a link to the cheapest one you will find. Also a pic of what mines looks like mounted with the rear poles. When folded down it also will fit under the poppy or oem cover.
Lastly, dont pay the dealer. You installing it wont void your warranty. Most dealers want over $600 for this exact same one. Plus labor. You are probably looking at 800 to 900. You can do it yourself for $420. Heck if i lived close by, id do it for free. It only takes about 20 minutes. The hardest part is assembling it and getting it ready to put on.
http://www.jmcamper.com/sunshop/index.php?l=product_detail&p=653
Hi cheappc,
here the link where I posted some pics with my Seadoo and the bimini.....
BR
Ingo
http://www.seadooforum.com/showthread.php?52173-new-SeaDoo-user-from-Germany&p=274587#post274587
