Total Power Failure
jpmalloy32
Hello All,
I am new to the forum and run a 2012 GTX155, great condition with a rebuilt engine. I was running it this weekend and after a hard landing over a wake, the PWC shut down completely. No power to the cluster, no beeps when I press the start button, and the speedo & tach gauges are locked at the position at the point the power failed.
I am new to the Sea Doo brand, so I was wondering if you could point me in the right direction. Could the MPEM have come loose, wiring harness, etc? Looking for some advice before I take it in to the dealership to have a look. No power to the cluster so I have no access to error codes.
Thanks in advance!!
Start with the simple and obvious things first. Check the battery cables, make sure the connections (both ends) are tight and clean. Next check all grounds. Then check fuses.
Lou
I'm with Lou. Check battery and connections first. Then main power fuses.
