ronmold
97' speedster w/720's. both engines are running poorly, L doesn't idle well and R has little power until I get on plane and then it gets going. Compression check shows 95 to 103 Lbs. which I believe should be much higher. I'm wondering if a top-end rebuild would do the job or after 20 yrs. is the lower end about done also?
