I am in the process of rebuilding a 580 motor. I have a couple of questions.
The oil injection system has been overrode. What is the premix ratio and will it be different for the first couple of hours to set the rings?
What oil do I need to run to set the rings? I have read not to use synthetic.
In the manual it says to use seadoo lube after engine is reassembled for the first couple of starts. Is this the same as silicone spray the seadoo lube is awfully expensive.
