To start things off this is the first time that I have had to post at this forum for help. I have had my 97xp since 1998 and other than a corroded starter switch shortly after I purchased by boat, I have had no mechanical problems whatsoever. Earlier today I put the boat in the water to go for a ride and noticed that it was a little more difficult than normal to crank and once it got going it just did not seem to run smoothly. I started paying a little more attention. When i take off the engine will rev up to the high RPM and once the boat planes off the rpms decrease. Once I was up and going I noticed that there was no difference in rpms or power from 3/4 throttle to full throttle. This is not normal. I ran the boat for the first time this season two weeks ago and it ran like a champ. I did notice that there were a couple of times then that it sputtered but nothing to noticable in performance. Normally, I can cruise anywhere from 45-52 according to the guage on smooth water. Today I was running appx 35-40 at full throttle. In the low RPMS there was no dimminishment of power. The only lack of power came in the high RPMs. I did get a new set of NGK plugs today thinking that was probably the issue, but that did not resolve. Any thoughts. I seems as if it is bad gas almost, but we ran the gas that was purchased at the same time in another PWC and had no problems. I was thinking may a carb adjustment or a cable is sticking. (My choke cable froze 2 years ago) but I just give the throttle about 5-10 pumps before cold starting and have no problems. But I may speculate that I may be looking at a rebuild. I have not tested the compression yet, but I come back that it runs perfect in the lower rpms and has plenty of power. Any thoughts? Thanks
