Please, some advice.
I have a 1996 sportster with a 717 engine. A seadoo dealer put 2 new pistons in it a couple years back and it ran fine for awhile. Then it would start cutting out while going full speed, just like it was running off one cylinder. It would not die, but it would just barely get you back to the loading dock. When you went to crank it the starter would sometimes begin to lock up.
That was last year, here is the main problem now. Thinking it needed a new starter, I put a new one on. Same result. It was locking up after maybe a half turn. I removed both plugs to see if the engine was locked up. The starter wizzed. No problem. Put one plug in, the starter turned the motor again, but you could tell there was a lot more load on it. Put the other plug in, (both plugs in), starter locks up.
Am I out of time? It does this with the wires off plugs. Do I have a valve stuck causing too much compression. Sorry, but not the best with one of these motors.
need help!
need help!
