VEKMAN2002
Recently I purchased a few parts that are confirmed correct for my 96 GTX.  The wear ring measures 3/16” wider than the housing should it not be flush like the original. Likely it would inhibit proper reinstallation of the pump.  Also. I got a carbon ring kit.  And the washers that seat inside the ring seal are slightly larger than the original it won’t allow the seal past the flange on the driveshaft. Has anyone had similar problems.   Titan sent new seals but I suspect they are also too big they would not confirm the actual size for comparison.
		 You'll be fine.  I think the best for the money is the stock wear ring though.  I put Loctite 609 on all my wear rings.  They tap in easier and they ain't coming back out. LOL  I've pounded a few in and I don't like doing that.  Good Luck !
 You'll be fine.  I think the best for the money is the stock wear ring though.  I put Loctite 609 on all my wear rings.  They tap in easier and they ain't coming back out. LOL  I've pounded a few in and I don't like doing that.  Good Luck ! I did make a jack/puller to install the wear rings without beating them up but this works better to me.
