Today I fired up the 2001 Challenger and was pleased that both engines ran well, at least on trailer. :hurray:
Then I was dismayed to find the right engine throttle wasn't closing when I pulled back the lever.:banghead: No trip to the river this week.
I can close the throttle by hand but it felt stiff. So I removed the flame arrestor to see what's going on. I discovered there is a spring loaded lever under the intake manifold connected to the engine block. It has a cable connected to the throttle lever, it appears designed to pull the lever back to the closed position when you pull back the lever. Is that all it's for?
The spring on that lever only has tension for the first half inch or so, after that it floats. I tried reaching under and turn the spring, but was unable to attach it to anything (and killed my fingers in the process).
Is that the only function of that lever below the intake manifold? Is the unloaded spring why my throttle won't close on its own? If so, how can I tension its spring?
