custompartsguy
I am stripping my carbs down to be powder coated. I have removed throttle blade screws before on carbs to do this, however these darn screws will not come all the way out on these carbs, I have found them on the parts site here for like $2.50 each screw thats alot for them. Anyways does anyone have a trick to getting these out....they just seem to seperate the throttle blade shaft but do not come out and the screw heads are stripping to where soon I will not be able to put a screwdriver on them. Maybe I will just cut the heads off but I still need to try to get them out first. And if you have any of these screws laying around it would be great.
Also my carbs have been rebuilt but not the fuel pump diapham...so I checked the parts sheet and it does not give a part number for it, where can I find just that piece? The other parts/gaskets are all new on the carbs, I need the fuel pump diapham, intake and carb gaskets and a head gasket.
