I am installing a new throttle cable on my 95 GTX. When i took the old one off the handlebar throttle lever I don't think it was installed properly. My parts manual says it should have a circlip (5mm) holding it in place. And what I think was a dust cap was not in place. I went out and bought a generic 3/16 e-clip. which I was told is the same thing as the seadoo part but only 25 cents instead of $4 from the dealer. Am I wrong?
Here is a pic of the cable(below). I am going to put the e-clip in the little groove, and the slide the rubber cap over the end of the metal end of the sleeve. This should cap the end of the throttle cable housing stopping dirt from getting inside the cabke housing. Is this right?
On my first try the clip is really hard to get on and spread quite a ways and does not spring back. It popped off pretty easy with a little pressure from a screwdriver. Is that normal?
I know this sounds minor but both my service manual and Clymer manual do not say anything about this part and I want to make sure I have it on right before I start adjusting the throttle.
