Lt1350
I have been working on the jetting and trying to get the top speed up on my 1998 951 Xp and have a few questions for group veterans.
The details are: fresh motor with +1.5mm pistons, .040 decked off top of cylinder, light case and cylinder porting, .8mm base gasket, stock head (I recut the squish band to 13.5 degrees and lapped in the gasket surface for flatness) chambers measure 51cc's, squish is .060" and both cylinders pump exactly 160 psi, carb chokes removed and a nice radius machined at air entry under proks. Running 50/50 93 pump gas and 112, so its just over 100 octane, new fuel lines. Solas Concord 15/20 with new wear ring. The hull and all components are all stock and in good condition.
I should mention this is with no accelerator pump, new 2.0 needle and seats, and the carbs have been pressure tested and are sealed up good. Using a new set of BR8ES plugs every time out.
Started out with 165 mains and 95 pilot with pop off @21. Machine seemed very lean off bottom with a bad hesitation and very rich on top. Would only turn 6400 and gps 58. Plugs were black.
Next I dropped to 160 mains and lowered pop off to 17 with 95 low jets. Was a little better off bottom and alot better up top. Turned 6800 and gps 62. Plugs looked alot better and were dark brown.
Currently tried 160 mains and 100 low jets @17 pop off. It's starting to get alot better off the bottom and top end was the same. Turned 6800 and gps 62 and the Plugs look almost black again. Overall this is definitely the best it has ran. Still feels like it should pull a little harder and turn more rpm up top.
With the current set up If I open the low adjusters 1.5 or more turns, the bottom end hesitation is gone and it's getting powerful and responsive. But after a 15 minute no wake zone it gets loaded up pretty bad. With the low adjusters open 1 turn it idles better and just seems cleaner and don't seem loaded up after the no wake zone, but then it has a lean hesitation and is not as responsive when riding in open water again.
I feel like it still needs larger low jets and smaller mains. It seems to REALLY like the fuel off the bottom.
Here are my thoughts and questions/concerns. If I go up a size or 2 on the low jets I should be able to close the low speed adjuster more and still not have that lean hesitation. Will that make it better in the no wake zone since the adjusters are closed more or will it load up worse since the jets are bigger?
Does dropping to a 157.5 main jet seem like a bad idea? That is alot leaner than most people seem to run on here! But the plugs look like it's still really rich and I am thinking that's why it won't turn more than 6800.
Lastly, how do I know if I need a pop off adjustment? It ran better when lowered to 17 but at that point the jetting was so far off I am now wondering if it is a little too low?
What are you guys' thoughts? Tia.
