ocod
Thoughts on Benol 2 Stroke Oil
Hello,
Compared to the quicksilver brand used at 40:1 to pre mix now which I smoke really bad at idle now??
Am I going to smoke more if I use lets say 3 over 2 or if I'm going to smoke anyways use #2 ??
I rather have that smell insted..
#1
The TC-W3 according to site only says its for the low ash and for warranty work which doesn't apply anymore.
http://www.klotzlube.com/proddetail.asp?prod=KL-306_Quart&cat=6
Pure synthetic lubricant. Extremely high load carrying capacity for reduced engine wear. Clean Burn™, No-Smoke Technology eliminates carbon and residue build-up. Use of this lubricant provides certified warranty compliance and protection. Exceeds JASO FD, ISO-EGD, TC-W3, TC-W2, TC-W and API TC low ash specifications for certified warranty compliance. Not alcohol compatible
or #2 Not clean burn(smokes more???)
http://www.klotzlube.com/proddetail.asp?prod=BC-175_Pint&cat=6
BeNOL®, the ultimate in 2-stroke lubricant when it comes to both protection and performance, is the choice of serious racers. Degummed and extra fortified for maximum reliability. BeNOL® provides twice the level of film strength and load carrying capacity of conventional castor oils. Blends with methanol alcohol and gasoline
or #3 Clean burn
http://www.klotzlube.com/proddetail.asp?prod=KL-100_Quart&cat=6
Pure synthetic bases are blended with 20% BeNOL® Racing Castor Oil. Provides engines the Clean Burn™ quality of Klotz® synthetic lubricants along with the exceptional film strength of castor oil. Degummed castor oil reduces ring groove deposits and protects engines in high RPM and extreme heat applications. Blends with methanol alcohol and gasoline
or #4 No castor oil and Clean burn
http://www.klotzlube.com/proddetail.asp?prod=KL-104_Quart&cat=6
R 50® synthetic lubricant was developed exclusively for use in Hi-RPM racing engines. TechniPlate® R 50® racing lubricity system protects engines from extreme heat and virtually eliminates engine wear. R 50® film strength is comparable to castor oil, but has the benefits of Clean Burn™ technology.
Hope to get a thought good or bad.
Threads usually don't go anywhere :cheers:
Hello,
#1
or #3 Clean burn
