This is a DUMB Question
awhite3600
My 95 GTI will literally beat your eyeballs out of your head this is really my first time on a pwc is this normal because none of the other ones on the lake seemed to? maybe i just need to not be a baby!
check your motor mounts, you could have a broken motor mount, pump issues, misalignment, maybe a badly chipped impeller even.
Grab the engine and see if it wiggles around from corner to corner. It sounds like Broken engine mounts.
Karl
sponsoons
Sponsoons look ok it just stays on top of the waves it doesnt go through them it hops over them, you can hear mine coming before you can see it, it revs higher in the air the slows in the water! i looked a mounts today but didnt shake them will def do that tommorrow :cheers: Anyways thanks alot
