Found what I believe to be a great starter boat. 2005 Speedster 200 w/ two twin Rotax 4-TEC four-stroke engine 370Hp supercharged im being told.
Priced at 6k including delivery from Maine of all places, is this just to good to be true?
According to NADA $6,5k retail, no delivery.
Pricing Suggested List Price Low Retail Average Retail
Base Price: $29,199 $15,250 $17,280
$6,565 $6,565
Engine: 351-400 HP (5.7L - 8.1L ##)
TOTAL PRICE $29,199 $28,380 $30,410
Deal is half in escrow/ 10 days for balance after delivery and acceptance.
As this is my first encounter in purchasing a boat, what questions should I ask before I engage? Ive listed below the specs.
Manufacturer
Sea-Doo
Model Year
2005
Model
Speedster® 200 (370 hp)
Price
Color
Red Viper
MEASUREMENTS
Length (feet
20
Length (inches)
0
Length (meters)
6.02
Length (LOA)
20 ft. 0 in. (6.00 m)
Beam
8 ft. 0 in. (2.44 m)
Draft (max)
12 in. (30.5 cm)
Deadrise
20°
Weight
2,770 lbs. (1,256 kg)
BODY
Hull Type
Modified Vee
Hull Material
Fiberglass
ENGINE & DRIVETRAIN
Engine Make
Twin Rotax
Engine Model
4-TEC
Horsepower
2x185=370
Engine(s) (std)
Twin Supercharged 185 hp Rotax® 4-TEC™ 4-Stroke, 6-Cylinder, 2,996 cc, 370 hp (3-Cylinder, 1,498 cc, 185 hp per engine)
Lubrication
Dry sump oil system
Oil Capacity
0.9 gal. (3.5 l)
Fuel System
MPI fuel injection
Fuel Type
Gas
Fuel Capacity
41 gal. (151 l)
Drive Type
Jet Drive
Impeller
Stainless steel, progressive pitch
Battery
Electric with D.E.S.S. (Digitally Encoded Security System) / 12 volt
Jet Pump
Axial flow, single-stage
Intake Grate
Inlet Clearance System
Exhaust
Dual mufflers
OPERATIONAL
Storage Capacity
46 cu. ft. (1.30 cu. m)
Maximum Capacity
1,400 lbs. (635 kg)
$6,565 $6,565
Manufacturer
Sea-Doo
Model Year
2005
Model
Price
Color
Red Viper
MEASUREMENTS
Length (feet
20
Length (inches)
0
Length (meters)
6.02
Length (LOA)
Beam
Draft (max)
12 in. (30.5 cm)
Deadrise
20°
Weight
BODY
Hull Type
Modified Vee
Hull Material
Fiberglass
ENGINE & DRIVETRAIN
Engine Make
Twin Rotax
Engine Model
4-TEC
Horsepower
2x185=370
Engine(s) (std)
Lubrication
Dry sump oil system
Oil Capacity
0.9 gal. (3.5 l)
Fuel System
MPI fuel injection
Fuel Type
Gas
Fuel Capacity
41 gal. (151 l)
Drive Type
Jet Drive
Impeller
Battery
Jet Pump
Intake Grate
Exhaust
Dual mufflers
OPERATIONAL
Storage Capacity
Maximum Capacity
1,400 lbs. (635 kg)
