GGuillot
I thought I'd share my experience of diving into the world jet skiing head first for those seeking the same goal. You want a decent jet ski but there's no way you're paying the price of a new ski. Go to any showroom floor and experience the sticker shock. If you have the time and the patience to work on something, these 2 strokes are where it's at, they're cool, sound awesome, are light and fun to ride.
1997 GTX - engine locked up, no trailer, no rear storage bin, no lanyard, sitting in a barn with rats having nested in it, last time it ran? PO said "last season". I always wanted a Seadoo 96' or 97' GTX remembered when they came out, they were expensive back then about $7500 out the door, not including a trailer, so I bit at $200. I quickly budgeted $1500 on the ski and factored in a single used trailer and miscellaneous, life jackets, oil, registering, etc, would put me in the bark park under $2000. Plus a ton of time, purchased the ski from the PO late Summer in 2017, and getting on the water wouldn't be realistic, it would be Spring 18' if I really dug in on it. Just recently got it running and out on the water.
Here's a breakdown of what you can be faced with to bring an old ski back to it's glory. I'll break down the minimum, above and beyond, and extra you can end up spending. Keep in mind, I did all the tedious labor, exception: getting the Rotary Valve cover machined. It's unrealistic to pay anyone to do all this or it would be very expensive.
Ski - $200
Cylinder resleeve - $330
Top End Kit (pistons) - $150
Balance shaft core swap - $105
Crankshaft core swap - $315
OEM carb kit/needles/seats - $136
Complete carb SS screw set - $19
2 carb blk springs - $10
Complete engine gasket set - $70
New rotary valve - $24
Fuel selector valve - $17
Fuel/oil/water lines - $80
New impeller wear ring - $40
Neoprene impeller seal - $4
Driveshaft rubber bumpers - $6
NGK spark plugs - $5
Oil injection filter - $8
Rotary valve machined to spec - $100
New buzzer or beeper - $8
Driveshaft c clip - $6
Driveshaft PTO boot SS ties - $3
Starter solenoid - $15
Rotary valve shaft bearings - $7
Engine temp sensor (wrong one on engine) - $15
Water box valve spring (old one in 4 pieces) - $7
Starter rebuild kit - $15
______________________________Total - $1695
Extra of some things I didn't need to do and some things to consider....
Re gelcoat on bottom and topside, (blk & wht) - $320
Rub rail SS rivets - $25
Support cradle for working on ski, materials - $50
New mats and seat cover (hydro turf) - $265
Single stage metallic paint on hood - $100
All decals - $155
Rear storage bin - $30
Hull registration lettering/taxes/1 year registration - $70
Media blasting engine parts (me going to a facility) - $16
Engine paint (3 cans of ceramic enamel) - $21
Auto bilge pump, lines and fittings - $95
New handle bar grips - $20
New starter button - $5
Seadoo embossed chin pad and silver vinyl paint - $20
New set/mode buttons and info center faceplate - $25
New DESS lanyard key (I programmed) - $25
Candoo Pro MPEM programmer (because I now have 2 skis)- $400
Engine aliment tool - $150
Rotary valve shaft pull tool (custom made) - $5
Rotary valve degree wheel - $13
Carb pressure tester - $18
Single ski trailer - $240
2 life vests - $100
XPS oil (2 gal) - $92
________________________________Total - $2260
+$1695
GRAND TOTAL - $3955
As you can see it adds up quick if you keep tabs over the last year after buying that $200 ski. I had a lot of tools already handy, engine crane, air tools, bench grinder, etc, some other things I bought are not listed and I'm probably missing something. You end up with excuses to go buy stuff, like a 2 inch sander, 7 inch digital buffer or a Viking battery charger..
Ski - $200
All decals - $155
2 life vests - $100
+$1695
GRAND TOTAL - $3955
